Re- torqing Head
Re- torqing Head
Hello i am going to re-torque the head on my Z1R tomorrow any tips on this or is it all straightforward, ie loosen off nuts in sequence and retighten?
Gary
Gary
I hope you haven't been lead up down the garden path or "screwed".
We have a problem.... too many methods of re-torquing?
I have often gone to re-torque after a period of, say, 200-300km, when engine has cooled, and found the original torque must be exceeded to move the nut at all. I marked the position of one nut, then backed it off, only to find I may get a extra angular movement at the same torque setting.
Hence, I'm of the opinion that, we may have to back off one by one, when re-torquing!
hanskloss wrote:done it today without backing off, only 3 nuts moved slightly, will check again at about 800 km, Garn's idea of marking the nuts makes sense might try backing off than, thanks
QUICK NOTE: Most important is to ensure threads are clean & lubricated so the REAL torque value is set....
Also make sure there's enough thread & room so the cap nut doesn't hit the top of the stud before the head is compressed fully!!!
I'd not get too worried, unless your Torque Wrench has recently been calibrated, it won't even be within the manual stated "range"
good point Pigford, threads were cleaned and lubed with moly grease, as to the stud's being too short - haven't thought about this, could they stretch that long? I thought about calibration before starting the build, but as my wrench was only used couple of times I had it first compared against brand new one and it was spot on, so left it as is.
