Evenin' Chaps,
More advice please.
Whats the script with removing a petrol cap.
Best way of removing old and fitting new?
Bongo.
Replace petrol cap on Z1000
"Keep on Rockin'!"
- Mark Tiller
Use a small punch to gently knock the old roll pin out, slightly smaller in diameter than the pin.
fuel cap
Bongo,
Remembr don't t**t it too hard------ you will bend the flimsy welded bracket that holds it to the tank and then the new one will not sit straight-----you have been warned, apply some patience more than brute force
Reecy
Reecy
Bongo. What worked for me was the flat screwdriver on a penknife. Insert it into the key slot and wiggle it about a little to make sure you have released all of the lock wafers. Then turn - clockwise i think. I posted a blog entry on my web site http://cheeme.weebly.com/1/post/2012/06/seized-fuel-cap.html
