Stripped Thread
Stripped Thread
Well it had to happen didn't it, even though I used new bolts, even though I was super careful, even though I used the correct torque the very last bolt that holds the cam caps on stripped the thread in the head and spun like a wheel. What to do? I know it will be an insert of some sort, can I do it myself, what's the best, do I have to take the head off, so many questions and so little ability and so fed up
i would advise not to use a longer bolt as sometimes they can damage the inner wall of the shim bucket if overtightened i have used these kits for many years
http://www.ebay.co.uk/itm/RECOIL-THREAD ... 572wt_1037
a 6mm insert is about 8mm long
demonstration on how to heli coil
http://www.youtube.com/watch?v=sQHRB2El ... ure=fvwrel
Carpy, you haven't lived with Z's, until you have stripped at least two or three of these 6 mm bolt holes, that hold the cap of the cam-shaft bearings.
There have been a plethora of reasons....
We all have done it, the more serious is usually with the ones with the dowel, as we have to go deeper with the helicoil, or timesert. Nevertheless, they all can be fixed.
Pertonic has an unique way of dealing with them that works, using studs and not bolts, however, just for one or two the usual fixes suffice.
In some cases we can go a lttle deeper with the drill, however standard practice with an insert usually fixes them... Good luck.
- The new bolts had a bad burr on the end of the thread.
The flange on one end of the cam-shaft was not lined up and jammed..
The tacho drive wasn't seated and jammed.
the torque setting was in Ft-lbs instead of in-lbs (manual was wrong!).. Personally, I don't use a torque wrench on 6mm
They were not tightened evenly....
and so on!
Users browsing this forum: Google [Bot] and 66 guests
