Z1 indicator panel wiring
malmojoe
#1 PostAuthor: malmojoe » Thu Aug 09, 2012 3:09 pm
Does anybody know which lamp goes where? Just looked at the wiring diagram in the manual and there's no colours on it. Very useful.
#2 PostAuthor: chrisu » Thu Aug 09, 2012 5:47 pm
Plug the battery in, turn ignition on and check which lamps light when.
Adjust location as appropriate
#3 PostAuthor: ADRIAN H » Thu Aug 09, 2012 7:36 pm
Hope this helps
malmojoe
#4 PostAuthor: malmojoe » Thu Aug 09, 2012 9:11 pm
Thanks Chris, but I didn't have my switches on at the time. All done now and I did it that way.
Adrian, thanks a lot for that I had some problems and had to try and follow the lines in the manuals diagram, which is not easy. If I had had this it would have been much quicker. I'll print it off.
BTW, my headlight wouldn't work and the fault was actually within the horizontal switch on the right control. I took the switch to pieces and cleaned the contacts with wet and dry and that sorted it. Just incase anyone else has that problem.
KeithZ1R
#5 PostAuthor: KeithZ1R » Thu Aug 09, 2012 9:14 pm
I use these much easier and less violent
http://www.outdoorvalue.co.uk/products/ ... fills.html
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
malmojoe
#6 PostAuthor: malmojoe » Thu Aug 09, 2012 9:39 pm
never seen those before :shock:
#7 PostAuthor: ADRIAN H » Fri Aug 10, 2012 5:04 pm
If you send me your email address I can email the wiring diagram over.
#8 PostAuthor: ADRIAN H » Fri Aug 10, 2012 5:38 pm
Glyn Diagram sent by email. Good luck. :D
Users browsing this forum: No registered users and 95 guests
