Flat track style z
debben1
#31 PostAuthor: debben1 » Thu Mar 08, 2012 8:32 pm
Been busy for a while so not much progress over the last couple of months but did manage to assemble the transmission into the crank cases today, crank has been balanced and welded and new h/d gerarbox bearings along with slipper style clutch centre
#32 PostAuthor: Ginger Bear » Thu Mar 08, 2012 9:33 pm
Good to see some progress Steve.
Can you fill us in on the 'mix & match' engine internals.......
...... Kickstart cases with Hyvo cam chain :?
# 104
debben1
#33 PostAuthor: debben1 » Fri Mar 09, 2012 12:48 am
Well spotted Ginger bear :shock: I wanted the earlier crank cases because of the way they mount into the chassis, the later crankcase are rubber mounted and use less mounting points. late ZX1100 crankshaft has a better rotor bolt, its much bigger and this means the rotor/starter clutch is less prone to spinning off with high rpm, the earlier cranks only use an 8 or 10mm bolt, the later cranks also use lighter webs rather than the heavier full circle cranks, these are heavier and give more centrifugal force which make changing direction quickly much harder for track days. Hyvo chain eliminates the need for all those expensive and heavy tensoiner wheels too. Input shaft is from the shaft shaft drive so I can fit the slipper style clutch inner and alluminium basket, output shaft is from the Z1000 MKII which has the smaller spline. Regards, Steve
debben1
#34 PostAuthor: debben1 » Wed Aug 15, 2012 1:21 pm
frame back fro stove enameling so the rebuild and final assembly begin :D
debben1
#35 PostAuthor: debben1 » Wed Aug 15, 2012 1:28 pm
steering bearings, yolks and engine fitted, swing arm needs fitted but needs finishing and forks require more work, this is my favorite stage of the bike build
#36 PostAuthor: Pigford » Wed Aug 15, 2012 3:58 pm
About time Romeo - keep at it lad :wink:
