Just a quick question i notice sometimes there is oil/fuel dripping out of the drain plug on what i think is the surge tank???(left hand side) is that anything to worry about?
drain plug?
- captaincaveman
drain plug?
Made a good start on the old gal today, battery fitted and apart from a stretched rear brake switch spring all seems good with lights etc, new plugs fitted, just waiting for ht leads, oil filter etc sprayed oil down into the cylinders , manually turned her over, then cranked her on the starter(plugs out), all seems good
Jay
81 GPz1100 B1
81 GPz1100 B1
- Mark Tiller
- captaincaveman
- captaincaveman
- captaincaveman
Thats the air filter housing - and a bit of oily fluid is acceptable - thats why there is a drain thingy at the end of the drain pipe
You often get a bit of oil/water due to condensation....
If there's loads p*ssing out, then maybe not so desirable.... check oil level ain't too high
- captaincaveman
wouldnt say its p*ssing out, you can just see abit on that picture, i wonder if maybe some got into there when i hosed it down, but that was a couple of weeks ago? could it be coming back from the efi?
Its such a strange set up on the bike, you got the filter box, then the air sensor flap thing, then this, covers such a huge area
Jay
81 GPz1100 B1
81 GPz1100 B1
That box (Airbox) has a tube from the crankcases that allow vaporised oil to feed up into the airbox and get burnt up by the engine. But some of it condenses in the airbox and drains out...so if you have a lot, then the crankcases are develoiong too much pressure and pushing more oil vapour up into the box.
A symptom of leaking piston rings allowing some of the exhaust to slip by and go into the crank cases.
- Mark Tiller
- captaincaveman
- captaincaveman
garyd wrote:That box (Airbox) has a tube from the crankcases that allow vaporised oil to feed up into the airbox and get burnt up by the engine. But some of it condenses in the airbox and drains out...so if you have a lot, then the crankcases are develoiong too much pressure and pushing more oil vapour up into the box.
ah ok, so you reckon i need to check the compression on each one to see if rings leaking?
Jay
81 GPz1100 B1
81 GPz1100 B1
- captaincaveman
