Single front disc brake master cylinder
Paul Whitehouse
#1 PostAuthor: Paul Whitehouse » Fri Aug 31, 2012 12:02 pm
Anyone got a front master cylinder for a single front disc setup for a zed?...not too bothered if it needs refurbishing. I'm building a `77 Z1000 special (Long, Low, Mean and Nasty...another drag zed in the projects section) and am only running a single disc setup to keep the look as period as possible for a drag bike. Cheers.
If it's too loud....too bad.
Mark Stratton
#2 PostAuthor: Mark Stratton » Fri Aug 31, 2012 12:12 pm
Paul
I'm sure I have one in the depths of the garage somewhere. I will have a look later on today and let you know.
Mark
pertonpc
#3 PostAuthor: pertonpc » Fri Aug 31, 2012 1:56 pm
There's some repros avail on ebay etc. from about £60ish for single disc.
If you don't have one to repair they might be a cheaper option as you won't need new internals and they come with bar clamps and lever. Have a look.
It's expensive and fiddly to replace the internals.
From Mark
Paul Whitehouse
#4 PostAuthor: Paul Whitehouse » Fri Aug 31, 2012 3:01 pm
Hi Chaps....thanks for the info. Mark (Pertonpc)...I've found the single disc ones on ebay for £62.00....up till now I'd only found the ones that were £90.00 !!!!....I've now purchased one of these...others had warned me that refurbishing one was a bit of a nightmare !!!!....thanks, Paul.
Mark Tiller
#5 PostAuthor: Mark Tiller » Fri Aug 31, 2012 3:34 pm
there is a circlip which is deep inside the bore, its a right bastard
07962421462
#6 PostAuthor: z1bman » Fri Aug 31, 2012 5:01 pm
Mark Tiller wrote:there is a circlip which is deep inside the bore, its a right bastard
ITS A PIECE OF CAKE IF YOU HAVE THE SPECIAL CIR CLIP PLIERS :D :D :
Tonka
#7 PostAuthor: Tonka » Fri Aug 31, 2012 6:44 pm
Hi, I have one off a Z1A if that is of any use?
Inheritance? What inheritance? He spent it all on booze, women and Zed parts!
Tonka
#8 PostAuthor: Tonka » Fri Aug 31, 2012 6:45 pm
Tonka wrote:Hi, I have one off a Z1A if that is of any use?
Whoops should have read the tread properly. Already sorted it seems.
