missfire/voltage at coils
bigalhudson
#1 PostAuthor: bigalhudson » Sun Sep 09, 2012 11:22 am
Tried to start the bike yesterday and only firing on No's 2&3 so had a look at the coils this morning. Ive got a new Dyna S ignition and coils fitted and its been running fine up to today. I could't trace the problem but was only getting 8.5 volts at the coils. Managed to fire it up and now only running on 1,3 and 4?. Then it cut out completely with no response to the starter button at all. Traced this problem to the kill switch which I've had problems with before. Stripped and cleaned the kill switch and and its now firing on all 4 but lumpy as hell and I'm still only getting 9.5v at the coils.
So: should I expect to get a full 12v at the coils? and if this is a problem what's the lightly cause. Wiring loom looks OK and I will chase through with a voltmeter to see if there is an obvious drop off somewhere
Any thought much appreciated
Z1000 A1
#2 PostAuthor: Pigford » Sun Sep 09, 2012 11:35 am
A good 12v + is a MUST at the coils....... I'd go s relay set up direct to ensure a good feed as the Kill Switch can often cause problems :??
#3 PostAuthor: z1bman » Sun Sep 09, 2012 11:50 am
have you checked the battery voltage/ charging system ? if that's all OK as pigford said try connecting a wire direct from the battery to the + side of the coils
#4 PostAuthor: chrisu » Sun Sep 09, 2012 12:35 pm
if you look at wired georges website it gives a good explanation of how to do the relay mod to get a guaranteed 12v to the coils.
Mark Tiller
#5 PostAuthor: Mark Tiller » Sun Sep 09, 2012 12:46 pm
07962421462
bigalhudson
#6 PostAuthor: bigalhudson » Sun Sep 09, 2012 12:55 pm
Yep that all makes sense, backfiring and sooty plugs as well. The bike had the relay mod on it originally but when I fitted the Dyna S I removed it as I didnt know what it was.
Thanks all
tlc
#7 PostAuthor: tlc » Sun Sep 09, 2012 1:07 pm
I just did the relay mod.
Despite new loom, new switchgear and new coils I only got 11volts at the coils.
Now get 12.6 at rest and 13.5 running.
Luvly :D
bigalhudson
#8 PostAuthor: bigalhudson » Sun Sep 09, 2012 1:14 pm
understand the relay part but whats a relay pigtail?
#9 PostAuthor: z1bman » Sun Sep 09, 2012 1:32 pm
bigalhudson
#10 PostAuthor: bigalhudson » Mon Sep 10, 2012 12:46 pm
Relay fitted and works a treat. Almost 13v at the coils. :D
Thanks again
hal
Relay mod
#11 PostAuthor: hal » Tue Sep 11, 2012 5:43 pm
Just done the relay mod on my z1b with dyna ignition and coils, the difference in the strength of the spark is amazing.
Bongoball
#12 PostAuthor: Bongoball » Tue Sep 18, 2012 6:07 pm
Evenin' Chaps,
I've read a few of the posts ref the "WiredGeorge" Coil Mod, and as I'm only getting 9.8 and 10.2v at the coils, want to have a go.
Now lectrix is a bit scary to me.
Did anyone take any "Guide for Dummies" pix as they did the mod?
Read the info on the Wired George website but pix would make more sense to me.
All help greatly appreciated.
Bongo.
"Keep on Rockin'!"
#13 PostAuthor: PAULJAC47 » Tue Sep 18, 2012 6:50 pm
Hiya Bongo, i am doing this mod on a Gs i am building you are welcome to have a look see when i have done it and copy to your bike or will give you a hand to fit one to yours one weekend at my place, get the bits off ebay and let me know,i am still waiting for delivery of my bits..Cheers Paul J
Bongoball
#14 PostAuthor: Bongoball » Tue Sep 18, 2012 9:12 pm
Ay up PaulJacola,
I don't care what the others say, I think you're a great bloke! :wink:
Have sent you pm.
Bongo.
"Keep on Rockin'!"
Users browsing this forum: No registered users and 105 guests
