Wornout Z650 camchain tensioner bracket.
#1 PostAuthor: zed1015 » Sun Sep 09, 2012 11:13 pm
Want a Z650 camchain tensioner bracket (Roller type camchain)
The steel swinging bit with the rubber wheel that the tensioner acts against.
Rubber wheel can be kaput as i only need the pressed steel bit.
j.b
#2 PostAuthor: j.b » Mon Sep 10, 2012 7:11 am
Do you have a picture of the part rob , am sure I'll have one somewhere
#3 PostAuthor: zed1015 » Mon Sep 10, 2012 8:02 am
Here's a pic of a 900/1000 one which is nearly the same except the 650 one is slightly different with a bigger wheel.
j.b
#4 PostAuthor: j.b » Mon Sep 10, 2012 10:49 am
looks like i've found one....if its right pm me your addy & i'll stick it in the post :D
#5 PostAuthor: zed1015 » Mon Sep 10, 2012 7:14 pm
Yep! that looks like a 650 one, The rubber wheel is as big as the idler wheels.
PM sent.
