Fitting seat strap
bigalhudson
Fitting seat strap
#1 PostAuthor: bigalhudson » Thu Sep 13, 2012 12:05 pm
Just waiting for a seat strap to arrive for my z1000A1 as it never had one. Looking at the seat pan I expected to find some holes in the side to connect/bolt/rivet through but can't see any signs that it's ever had one fitted. How are the seat straps originally fitted?
Cheers Al
#2 PostAuthor: z1bman » Thu Sep 13, 2012 12:14 pm
there should be a 6mm nut welded to either side of the seat pan
tlc
#3 PostAuthor: tlc » Thu Sep 13, 2012 1:06 pm
The welded nuts are not present on US spec seat bases.
Good luck :??
bigalhudson
#4 PostAuthor: bigalhudson » Thu Sep 13, 2012 1:52 pm
Yep its an american import. Presume they didnt have them fitted as standard then. Think its worth doing to balance the look of the seat. I'l get me drill out once the straps arrived.
