Rear caliper
ricky13
Rear caliper
#1 PostAuthor: ricky13 » Tue Oct 02, 2012 2:56 pm
Hi
Just doing the rear calliper on gpz750r1
It has an odd set up with bleed nipple running through main bolt for hose coupling
There is another bolt on the other slide can this be used for bleed nipple it looks big, any idea of size
I am fitting braided hoses
Thanx again
needaz1100r
#2 PostAuthor: needaz1100r » Tue Oct 02, 2012 4:10 pm
Sounds to me like someone stripped the bleed nipple, fitted a banjo with bleed nipple and drilled and tapped the original bleed nipple hole and blanked it with a larger bolt.
ricky13
Caliper
#3 PostAuthor: ricky13 » Tue Oct 02, 2012 4:44 pm
Could be but all looks ok does not look bodged
Thanx for the prompt response
needaz1100r
#4 PostAuthor: needaz1100r » Tue Oct 02, 2012 9:15 pm
A picture tells a 1000 words....
