Any input appreciated
sockpuppet wrote:Gpz output shaft (better than a J as it uses a large nut for the sprocket retention insread of a bolt)
Is this a Unitrak Gpz shaft ?
Its just that i have two GPZ1100b2 `s and both have the bolt type ,
and world`s most complex retaining washer system !!!!
Regards
Mick
zed1015 wrote:For the J style non kickstart engine .
You need -
gpz/j gear selector shaft.
gpz/J inner cover/seal holder.
gpz/J sprocket cover.
zed1015 wrote:sockpuppet wrote:Gpz output shaft (better than a J as it uses a large nut for the sprocket retention insread of a bolt)
Regards
Mick
Ah. yes! a unitrac one.
