1100 Septic StreetRod
Mr Puffin
#1 PostAuthor: Mr Puffin » Sun Oct 07, 2012 4:05 pm
Just been and collected a Crashed 1100 spectre this afternoon :oops: It was Cheap but then it is a Spectre
The Bike had been crashed and then parked up, about 5 years ago. Most of the impact appears to have been taken by the bars instruments headlight area. Looking at it i think i can see a bike in it ........ Somewhere !!
Image :!:
Its dirty and horrible so a good power wash is required :P
nanno
#2 PostAuthor: nanno » Sun Oct 07, 2012 7:28 pm
I can see a very tasty base underneath it all!
Mr Puffin
#3 PostAuthor: Mr Puffin » Sun Oct 07, 2012 9:54 pm
nanno wrote:I can see a very tasty base underneath it all!
:lol: :lol: yes me too, kind of.............
I gave it a power wash which has helped :roll:
Then this evening used around 40 minutes Repaired some Wires, fuel, plugs and caps and it runs :wink: So very happy for NKR2000 or just less than £200 :)
#4 PostAuthor: paul doran » Mon Oct 08, 2012 10:15 am
be good to see another Septic being revived
Mr Puffin
#5 PostAuthor: Mr Puffin » Mon Oct 08, 2012 10:01 pm
paul doran wrote:be good to see another Septic being revived
:lol: Septic yes how apt :oops: Paul i will definately do something with it but to what form it will take is as yet undecided
Mr Puffin
#6 PostAuthor: Mr Puffin » Mon Oct 08, 2012 10:13 pm
It cleaned up fairly well :roll: and with the removal of some of the damage looks alot better....... l
nanno
#7 PostAuthor: nanno » Tue Oct 09, 2012 7:26 am
I have a brand new Z1000P tank kicking about in my shed, doing nothing... and judging by that rear tank mount of yours, it should be a straight fit.
(Which it isn't on a Z1000J and that's why it is still sitting on the shelf)
I may have to add, it was painted flat black with a rattle can to prevent corrosion on the outside, but if memory serves me right, it had a small ding somewhere.
PM me, if you're interested.
Greg (located in Austria, Central Europe)
Mr Puffin
#8 PostAuthor: Mr Puffin » Tue Oct 09, 2012 3:35 pm
nanno wrote:I have a brand new Z1000P tank kicking about in my shed, doing nothing... and judging by that rear tank mount of yours, it should be a straight fit.
Thanks for the offer Greg but at the moment im still on the fence reguarding the build direction, i really dont like the Spectre/LTD look :| Which is why i was trying the J tank. I could just paint the whole thing mat black + T Bars and run it"allmost" as is :oops: or i have a set of leading link forks for a Z1100 and a Ural sidecar :idea: but the swingarm pivot width seems to be around the 285mm mark so if i can convert to chain i have a Ducati 916 arm on the shelf......So im spoilt for choice :??
garyd
#9 PostAuthor: garyd » Tue Oct 09, 2012 5:57 pm
Give me a heads up on the tank if Mr puffin don'r want it...I'm trying to find a tank that will sit on a GPZ1100 frame....it's bloody wide !!
Mr Puffin
#10 PostAuthor: Mr Puffin » Tue Oct 09, 2012 6:29 pm
garyd wrote:Give me a heads up on the tank if Mr puffin don'r want it...I'm trying to find a tank that will sit on a GPZ1100 frame....it's bloody wide !!
Gary if you need it now pm Greg, which model GPZ do you have Uni :?: Because thinking about it the Tank i tried on was probably off a B1. Having not seen any reference to tank differences i figured the twinshock tanks would be the same
nanno
#11 PostAuthor: nanno » Tue Oct 09, 2012 6:36 pm
Will do, I'll have a quick look at it, when I am back in my shed. If I don't contact you until the end of the week, please send me a gentle reminder, things are quite busy overhere at the moment... :roll:
@Mr. Puffin:
I love your mattblack and highup bars idea. Classic twirled Z-bars would be ace!
Greg
Mr Puffin
#12 PostAuthor: Mr Puffin » Thu Oct 11, 2012 10:54 am
:oops: Sorry for the misinformation in daylight the J/GPZ tank will fit. The spectre`s 2 front Tank locating mounts stick much further out than the J so need trimming back slightly. This allows the tank to sit forward correctly
Mr Puffin
#13 PostAuthor: Mr Puffin » Wed Oct 17, 2012 8:32 pm
The seat was in a real bad way and not just from the crash damage.
Then i tried on the Zed style seat unit, but i cant really say it looks good :|
I think it just looks too wide, i suppose it being white does not help out either......
I then offered up an old chopped around Z9 tail, i think this may work ok with a homemade 3/4 lenght seat. Giving the bike a more compact look. A sort of Wrench monkey type of build. I have some Superbike bars on order which should give the look im after.
sanderz
#14 PostAuthor: sanderz » Wed Oct 24, 2012 5:15 pm
Mr Puffin wrote:I then offered up an old chopped around Z9 tail, i think this may work ok with a homemade 3/4 lenght seat. Giving the bike a more compact look.
I like the look of that with the Z9 tail.
Stick at Mr Puffin whichever way you go with it - even the mad max matt black look gets my vote :up
Wots up DOHC
#15 PostAuthor: paul doran » Wed Oct 24, 2012 5:39 pm
I will post a picture of a Septic one of Our members altered
