starter clutch
sme
starter clutch
#1 PostAuthor: sme » Tue Oct 09, 2012 4:11 pm
how do i get the starter clutch off the end of the crank?
i have taken the small bolt that holds it on,
just need to get it off so i can check the bits
#2 PostAuthor: z1bman » Tue Oct 09, 2012 5:44 pm
use the centre bolt from the top yoke to remove the rotor if you don't have the proper puller
#3 PostAuthor: Pigford » Tue Oct 09, 2012 6:00 pm
.........also the rear wheel axle fits too = apparently :wink:
750steve
#4 PostAuthor: 750steve » Tue Oct 09, 2012 6:16 pm
Pigford wrote:.........also the rear wheel axle fits too = apparently :wink:
Yip, a 20mm axle works too. Did on my GPz750 engine & Z750B Twin Engine. Havent tried the 650 yet
Users browsing this forum: Jigginjim and 103 guests
