GB's 'Period' modded Z1000A2 with 'Toast Racks'
- paul doran
Cheers Paul.........
Been busy with me shocks.
Stripped 'em all down, cleaned up the bodies, then treated them with Kurust, before polishing them again.
Springs were rubbed down, then sprayed with 'smooth' Hammerite, before spending an hour in the oven.
Mikey was bribed (with cakes) to polish the top retaining rings. I think they contrast well with the black paint.
Some of the parts went into the ultrasonic cleaner........ Some of 'em didn't fare too well.
These were rubbed down & treated to a coat of Halfords plastic primer, followed by a coat of leftover 'Firecracker' red from me snotter project, then given a coat of clear lacquer.
I ended up with this lot;
Used these 'ladder ties' from Machine Mart as an 'impromptu', but effective spring compressor.
End result looks like this;
And fitted to the bike with my newly supplied acorn nuts.
Is Vic There
Thanks lad's. Just ordered a couple of 'sample' bungs from skiffy.com
http://www.skiffy.com/docs/menufr.cfm?t ... gindex.cfm
These should push into the top of the resevoirs & tidy em up a little more..... Might even add a set of stickers!
http://www.ebay.co.uk/itm/130765073479? ... 500wt_1282
Is Vic There
- coldsummer
Is Vic There
Is Vic There wrote:Tell you what GB, I'll buy you the stickers for sending over the inner sprocket cover, just let me know your address.
Email from the seller. They'll be in the post in the morning, thanks for the help Mr Bear you are a top bloke.
Keith, I've since found the same thing here..... For a lot less dosh!
http://www.ebay.co.uk/itm/Set-of-2-x-2- ... 2a1289b680
