Non starting Z1000R
martinz1000r
Non starting Z1000R
#1 PostAuthor: martinz1000r » Tue Jul 17, 2007 9:37 pm
I have just transplanted a replacement engine in to my 1983 Z1000R. When it left the donor bike it started on the button. I transplanted carbs, exhaust etc so nothing different or new in set up. It turns over, has a strong spark, fuel in the tank but not a hint of firing! Got to be something really simple but I can't work it out. Help please because I really would like to ride it again!
Iain marshall
#2 PostAuthor: Iain marshall » Tue Jul 17, 2007 9:52 pm
Martin check the wiring to the coils is the right way round just in case you've mixed up the left and right coils
london calling
#3 PostAuthor: london calling » Tue Jul 17, 2007 11:25 pm
Martin,check that you've actually got fuel getting to the carbs.
Make sure that the vacuum hose is connected,etc.
Hope you get it sorted out soon.
Jack
steve f
#4 PostAuthor: steve f » Wed Jul 18, 2007 7:08 am
engine kill button on the handlebars
spiny
Re: Non starting Z1000R
#5 PostAuthor: spiny » Wed Jul 18, 2007 1:05 pm
martinz1000r wrote: has a strong spark,
If it was the kill button it wouldn't be sparking....
Pass the angle grinder and the puke green paint..
#6 PostAuthor: Rich » Wed Jul 18, 2007 4:48 pm
Ignition 180 deg out - advance/retard cam or wiring.
london calling
#7 PostAuthor: london calling » Wed Jul 18, 2007 5:14 pm
Make sure the choke mechanism is operating fully and sliding along it's full range of movement.
Guess who got caught out when trying to start up after a full re-build :oops:
Jack
martinz1000r
#8 PostAuthor: martinz1000r » Wed Jul 18, 2007 5:21 pm
thanks for the tips! Certainly not the kill switch as I have a spark. I'll retrace my steps on the fuel system without losing my temper this time tomorrow. Can anyone confirm that the vacuum pipe runs from fuel tap to right hand carb, left hand is blanked and 2 and 3 are linked as this is how it is set up.
london calling
#9 PostAuthor: london calling » Wed Jul 18, 2007 9:00 pm
Just thought Martin,set the fuel tap to prime to help with initial start-up.
Jack
martinz1000r
#10 PostAuthor: martinz1000r » Sun Jul 22, 2007 6:27 pm
Success - we are up and running! Thanks for all the tips - fuel tap on prime did the trick :D
london calling
#11 PostAuthor: london calling » Mon Jul 23, 2007 5:02 am
Pleased to see that you got it sorted Martin :D
Jack
