Yet anuvver new project - How long will I keep it this time?
Crofty
#31 PostAuthor: Crofty » Mon Oct 15, 2012 2:48 pm
Should be able to start charging for admission to see the Pigford Collection soon Mark. Must say though that that one looks to be a good solid bike to start changing into something better looking than it does now.
#32 PostAuthor: Pigford » Mon Oct 15, 2012 3:20 pm
KWACKERZ1 wrote:looks like the only way is up!!
Needs a lot of work,
How many projects on the go now?
Harris,
W650
This z
mk2 ?
Should keep you busy over the winter months!
:lol:
Mind you I cannot criticize, currently up to 4 of my own and have taken on someone else's :roll:
Harris is a slow burner - as it's burnt most of my savings :roll:
W650 is sorted - no more messing, just tidied it up a bit & riding it.
MkII - errrm, gonna play with it over winter :??
LTD - no rush, as and when............. gonna copy Ginger Bears bike
Crofty - can't charge for viewing as it's all posted on here !
Hinckley - Just joking about the GPz cam end-caps! My Mk.II Sprinter has a GPz head, a common performance mod for Zeds.
Padders
#33 PostAuthor: Padders » Mon Oct 15, 2012 3:45 pm
What about my favorite triumph I hope you still have that one.
#34 PostAuthor: Pigford » Mon Oct 15, 2012 3:56 pm
Padders wrote:What about my favorite triumph I hope you still have that one.
Yep - thats a keeper along with me bestest Z1000 :lol:
RALPHARAMA
#35 PostAuthor: RALPHARAMA » Mon Oct 15, 2012 6:17 pm
Where are you putting them all? Last time I visited you had too many bikes for your garage and that was a lot less :shock:
Ralph Ferrand
#36 PostAuthor: Pigford » Mon Oct 15, 2012 6:52 pm
Ralphy, this ones under a tarp on the drive .... Harris at assortment of spares locked away safe at work :wink:
You'd have room for a dozen more if it weren't for all those TOOL's :lol:
#37 PostAuthor: Pigford » Tue Oct 16, 2012 4:21 pm
Started to get some of me stash together - in readiness for tarting the old heap up.....
That rear wheel is a genuine Z1 item - you can tell by the lack of "brake lining" indicator on the hub!
Got this to fit as well - need summink nice and comfy at my age :roll:
#38 PostAuthor: Pigford » Sun Oct 21, 2012 11:20 am
Got the missing engine mounts from D&K bikes, via eBay - no probs :shock:
Then decided to rip off the rear muddie & light unit and fit the neat one I had stashed in the garage........
......... looks good me thinks :wink:
Gonna clean up & re-paint the Jock Kerr 4:1 before fitting it to see how it looks - then strip out the rear end and bung the JMC & Z1 wheel in along with some proper shox.....
The more I look at this bike, the more I find that needs doing :roll: Hey-Ho, way to go - gimme summink to play with for a while :lol:
sanderz
#39 PostAuthor: sanderz » Wed Oct 24, 2012 5:04 pm
Looking good already there Mr Pigford :up Whats that back light off - ZZR600 or ER500 maybe? Fits in well under the tail piece anyhow
Is that an air tank built into the JMC?
Pigford wrote:
Proper swingarm an all - slotted adjusters are how they should be :wink:
Wots up DOHC
#40 PostAuthor: Pigford » Wed Oct 24, 2012 5:38 pm
That is indeed an air tank - not that I intend to use that function :lol:
The light is off an ER5n or summink like that :wink:
Got me some more wheels - did a swap for some XR400 dirt wheels.....
....... dunno what I'm gonna do with them yet though :twisted:
#41 PostAuthor: Pigford » Fri Oct 26, 2012 3:24 pm
Had a spare few minutes this lunchtime, so I had a play with my wheels........ seem to be drifting away from my original plan - too much temptation stashed away :??
These are some re-furbed Z900 forks I did a swap for, a few years back; re-chromed, new seals & oil.
This JMC is for a drum brake wheel, but not difficult to overcome.
I had a new disc for my old XR400 and its a nice chunky 4.5mm item, rather than the 3mm standard thing! Obviously this route would open up a can of worms - needing: spacers galour, 1-off sprox & axles, caliper adaptor plate, etc..... :shock:
RALPHARAMA
#42 PostAuthor: RALPHARAMA » Fri Oct 26, 2012 3:38 pm
I like the understated minimalism of this design :D
Ralph Ferrand
#43 PostAuthor: Ginger Bear » Fri Oct 26, 2012 7:08 pm
vduk wrote:I like the understated minimalism of this design :D
:rir :rir :rir
# 104
coldsummer
#44 PostAuthor: coldsummer » Fri Oct 26, 2012 9:56 pm
A bit too much rake on them forks imo.
#45 PostAuthor: ADRIAN H » Sat Oct 27, 2012 7:34 pm
Its in stealth mode. :lol: :lol: :lol:
