Pressing out a steering stem
needaz1100r
#1 PostAuthor: needaz1100r » Mon Oct 22, 2012 1:45 pm
I assume it is pressed down out of the bottom of the yoke.
I was looking for tips on t'interweb and found this...
http://pantablo500.tripod.com/id11.html
Please tell me he didn't use aluminium duct insulating tape to pack the hole between the bottom yoke and stem and then go racing!!!!
Mark.
#2 PostAuthor: Ginger Bear » Mon Oct 22, 2012 2:00 pm
You are correct. If it can be pressed out it will go downwards.
Oddly enough, I've just posted this on another thread;
This is what I did the last time I needed to modify a stem. came from a Z1000J & was welded. :shock:
1. Cut off what you can.
2. Stick it in a lathe......... even a 'baby' Myford will do. :roll: :wink:
3. Machine it to fit your replacement bottom yoke.
This method is particularly useful if the replacement yoke was fitted with a larger diameter stem. Note the small 'lip' left on the bottom of the stem to stop it being 'pulled' through the yoke.
# 104
needaz1100r
#3 PostAuthor: needaz1100r » Mon Oct 22, 2012 2:15 pm
Thankyou.
I need to keep the bottom yoke, I want to swap stems between 2, funnily enough Z1100R ones - same as Z1000J3, so I guess I'll just keep pressing, 10 tons might not be enough.
If it's an aluminium yoke, it can't be welded to a steel stem though, surely?
Mark
#4 PostAuthor: Ginger Bear » Mon Oct 22, 2012 2:54 pm
No it surely can't.
# 104
