Yoshimura / Moriwaki Ignition Cover
Would someone be able to measure one of these covers if you have one fitted to one of your bikes. I fancy my hand at machining one of these up.
Let me know if you are happy to measure and I will let you know which measurements I need.
LE to JOG on a z900
P.U.M.
P.U.M.
Steve the main reason for doing this is when I am away on the ship I normally have a few hours spare in an evening and a workshop available with a lathe, milling machine etc etc.
I have thought a few times I should make something for myself during that time.
In answer to your question I probably could do and if I get stuck bearing in mind that I have not really done any machining for years. I could always get one of the fitters to help me !!
What design would you want, finned on the top and plain on the sloped part ?
LE to JOG on a z900
P.U.M.
P.U.M.
It all depends Mike.
Are you planning to replicate the Yoshi lettering? If so I would fancy the fins, or perhaps grooves on the sloped part, if there is no lettering, then fins on the upper part would work best.
Don't break your balls over it though Mike, it's only for the 'Yoshi' pistoned toaster, which is all a bit 'tongue in cheek' anyway.
Hopefully it'll get ripley a few less bidders .
I am looking for someone to be able to mill the Moriwaki logo into some alloy to have welded onto a zephyr550 points cover as they have already got the cutaway at the lower edge. Sadly thet only fit the 550/650/750 motors
Jumbo can you mill out the logo? Happy to pay you to do it. Jim
garyd wrote:F' gawd sake....some one measure it...
Sorry, I aint got one, otherwise I would have measured one.
Users browsing this forum: No registered users and 123 guests
