1100 Septic StreetRod
- paul doran
sanderz wrote:
I like the look of that with the Z9 tail.
Stick at Mr Puffin whichever way you go with it - even the mad max matt black look gets my vote
Me too it kind of takes away the Septicallity
At the moment im just sorting the electrics, damage to the harness wiring in some J switch block & removing alot of things
paul doran wrote:I will post a picture of a Septic one of Our members altered
That would be good Paul
paul doran wrote:kz900B1 wrote:H'm Paul, Is this you warming to Septics now you have scratch'd the Shed1'r Itch
Colin I have owned that Shed 1R for a very long time
and am happy to promote them but I draw the line at Septics
I will never own one![]()
The lefthand footrest plate was destroyed, finding another is apparently difficult. Spectres beind that ugly that not many sold. Looking at the footplate bolt pattern then comparing to Vduk`s rebuild the Z1100 mounts look to be the same as the septic. So thats an option allthough i think perhaps a set from an UT might suit what i have in mind
"Hideous"
"Hideous"
- paul doran
needaz1100r
- ZedHead
Iain marshall
- paul doran
- Timothy Comerford
- Regular Poster
Tim's Septic!
Hi Mr Puffin. I knew it was only a matter fo time till the Septic became a topic for discussion. You can't keep a good thing down! I have only done a couple of hundred miles on my one.. It goes well but the orignal shocks were knackeres. I now have a set of Hagons thanks to Paul,
Good luck with the re-build ..........and enjoy the begrugers!!
Tim.
Tim.
"By far the best proof is experience"
