master cylinder paint
				steve big zed
 - Regular Poster
hi, Anyone know a suitable spray paint for the front brake master cylinder. thanks steve
				Is Vic There
When you bleed the system just have a spray bottle with water and washing up liquid in it, spray the area where the bleed nipple is first and if you have a big spill spray a shit load where the brake fluid has gone. The thing is brake fluid will travel over the washing up liquid / water mix
Got this tip years ago when I first started work as a diesel fitter when I was 15, old bloke who'd done this trick for years.
Vic
Vic
						Is Vic There wrote:When you bleed the system just have a spray bottle with water and washing up liquid in it, spray the area where the bleed nipple is first and if you have a big spill spray a shit load where the brake fluid has gone. The thing is brake fluid will travel over the washing up liquid / water mix![]()
Vic
clever!
Andy
