Front brake master cylinder
ricky13
#1 PostAuthor: ricky13 » Fri Nov 02, 2012 4:30 pm
Hi
I am looking to upgrade my front brake master cylinder set up to a more modern one
It's going on gpz750r1 twin shock
Any help or ideas would be great
Spen72
#2 PostAuthor: Spen72 » Fri Nov 02, 2012 8:03 pm
Hi there ricky...dk are doing a new twin disc master cylinder for £50 on eBay if that helps...I'll get the add number if you want it...Spence
#3 PostAuthor: Ginger Bear » Fri Nov 02, 2012 8:20 pm
Ricky,
Pretty much any 5/8th master cylinder will work.
If you want a remote reservoir then look for something like ZX7R, If you want an 'integral' reservoir then ZZR or ZRX will work well, but be cautious of the angle of the reservoir on some of the 'integral' stuff.
An integral resevoir designed for a sports bike, may not work well with high, 'sit up & beg' bars, just because it will hard to keep the fluid 'level'.
I hope this make's some sort of sense. :roll:
# 104
kas750
#4 PostAuthor: kas750 » Fri Nov 02, 2012 8:28 pm
I used a Zx9r master cylinder on my kh400.The reservoir that came with it was a little bit bigger than would of liked so i got a rear reservoir from a 50cc chinese trailie.
ricky13
#5 PostAuthor: ricky13 » Fri Nov 02, 2012 8:39 pm
Brilliant guys that's the info I was after I will check out eBay and see what is suitable
Many thanks
Jumbo
#6 PostAuthor: Jumbo » Fri Nov 02, 2012 9:09 pm
I fitted a ZRX Brake Master Cylinder as these also have the fitting for the mirror. Also as I converted my clutch to hydraulic I used the ZRX Clutch Master Cylinder.
LE to JOG on a z900
P.U.M.
Spen72
#7 PostAuthor: Spen72 » Fri Nov 02, 2012 10:25 pm
Hi Ricky...that add number on eBay for the 5/8 master cylinder is 350612398655...Spence[/u]
Z1parR
#8 PostAuthor: Z1parR » Fri Nov 02, 2012 10:33 pm
0172 . Geoff Parr
Z1parR
#9 PostAuthor: Z1parR » Fri Nov 02, 2012 10:36 pm
Or if you want a ZRX one then i've one with lever , PM me :D
0172 . Geoff Parr
Spen72
#10 PostAuthor: Spen72 » Fri Nov 02, 2012 11:48 pm
Thanks for finding the link z1parR...my phones not that good...Spence
ricky13
Remote res
#11 PostAuthor: ricky13 » Sat Nov 03, 2012 5:14 am
Thanks again
I will go for remote res I think
Thanks for the link and offers
Any remote reservoirs with levers pm me
Thanx
Users browsing this forum: doebag and 69 guests
