engine cases
engine cases
as above needed,z1r engine cases,bored out ones a bonus but not essential.need them for dragbike engine rebuild.cheap as possible,will swap and deal for.what you got,what you need,what you want.
- ade woollams
what happened to hat dragbike you where doing with the turbo. the yellow one?
- ade woollams
what happened with that motor.i may have a set but they need work and a main cap
Well when i stripped it down last time.i found some damage caused by an over enthusiastic wanna be mechanic.one of the barrelstud threads had a chunk missing.from over tightening of head.also a repair on the starter motor area.i have disided not to trust it with this damage using nitro.so thats why im after some more.
- ade woollams
somtimes if the cases are bored out to far you will get a crack in the case when pulling the head down .i had a set of cases like that ,and they had been done by NCKracing.they where on my prostock bike when i bought it .all i done was V filed the crack and got it ally welded run a tap down the thread after and its still ok now did you mean NOS not nitro.are you still runnng the turbo or just nos.
i find the gpz motor out 1500 and big cams enough
