Z1A "old school" rebuild
DDZ900
andys wukshop
#46 PostAuthor: DDZ900 » Sun Nov 11, 2012 6:31 pm
Very talented our andy ! lovely workshop when u see it in the flesh. :roll:
andy c
old school rebuild
#47 PostAuthor: andy c » Sun Nov 11, 2012 6:40 pm
And again from the front, next job to make the lines off to make them go between the carbs and air box, over the top of the engine and to the cooler, its going to be tight but will look a lot better then going round the side of the engine.
ollie
#48 PostAuthor: ollie » Sun Nov 11, 2012 7:10 pm
You certainly have a talent Andy for metal work ,only wish i could make things like that . :wink:
Z1B
#49 PostAuthor: Z1B » Sun Nov 11, 2012 8:50 pm
My kind of post love old machinery, do you use invertors Andy or are you privy to a 3 phase supply, or is everything single phase
Always Learning. :wink
andy c
old school rebuild
#50 PostAuthor: andy c » Mon Nov 12, 2012 7:24 am
Z1B wrote:My kind of post love old machinery, do you use invertors Andy or are you privy to a 3 phase supply, or is everything single phase
Only single phase supply to workshop but my milling m/c is running inverter, this gives me total speed range on the motor. No having to change drive belt / pulley configeration to select speed , cutter speed can be increased/de-creased during the cut to give best surface finish on workpiece.
Is Vic There
#51 PostAuthor: Is Vic There » Mon Nov 12, 2012 10:59 am
Love your work mate, very good and I'd love a man cave that that.
andy c
old school rebuild
#52 PostAuthor: andy c » Mon Nov 12, 2012 1:37 pm
Centre stand stop finished, needed to get this done ,bike now in final stage of being finished and need to get my bandit 1200 on it for a service and bloody good clean.
RALPHARAMA
Re: old school rebuild
#53 PostAuthor: RALPHARAMA » Mon Nov 12, 2012 4:10 pm
andy c wrote:Image
That's where you need a second bike bench :lol: I now have one for servicing etc and one for the project bikes :D
Ralph Ferrand
Z1B
#54 PostAuthor: Z1B » Mon Nov 12, 2012 6:28 pm
Cheers Andy got a small invertor myself on one of my machines, but I hope to get my generator sold and replace it with a larger unit, in the future and wire the whole place for three phase save fing about burning diesel when not needed.
andy c
old school rebuild
#55 PostAuthor: andy c » Mon Nov 12, 2012 6:56 pm
Lines in, what a fight a length of -8 hose can put up
andy c
old school rebuild
#56 PostAuthor: andy c » Mon Nov 12, 2012 6:59 pm
then between carbs and airbox.
andy c
old school rebuild
#57 PostAuthor: andy c » Mon Nov 12, 2012 7:03 pm
Over the engine, under frame to the cooler . Job done.
#58 PostAuthor: Pigford » Mon Nov 12, 2012 7:25 pm
Looks damned smart :!:
My Z1000 has the same arrangement - but cooler connections are on top - gave better clearance and also helps make most of extra oil capacity.....
andy c
old school rebuild
#59 PostAuthor: andy c » Mon Nov 12, 2012 7:59 pm
Piggy I tried it your way round for the same reasons as you but in that position on mine I had issues with full lock on steering hitting it. Last time I fitted a oil cooler I had electronic tacho and old cable drive blanked off, this is the way to go on trick bikes, you loose the cable and it gives you a bloody huge space to play with.
#60 PostAuthor: Pigford » Mon Nov 12, 2012 9:27 pm
Ahhhhhhhhh, I must admit my steering lock is rather limited :roll:
