z650 choke railm
johno
z650 choke railm
#1 PostAuthor: johno » Sat Nov 17, 2012 10:26 pm
Doe's anyone have a choke plunger lifting arm for 77b1 z 650 its the end arm that lifts the choke plunger right hand side?.
Cheers john.
pertonpc
#2 PostAuthor: pertonpc » Sat Nov 17, 2012 11:48 pm
Try John Browse at Wrexham if you are struggling to get one on here.
Where did yours vanish to?
johno
#3 PostAuthor: johno » Sun Nov 18, 2012 7:54 am
Hi thanks for that the bike had been standing for a while before i bought it and the choke plunger seized when the guy lifted the lever i guess it must of just broke off, not a bad idea to keep an eye on them to make sure they dont get sticky.
cheers john.
pertonpc
#4 PostAuthor: pertonpc » Sun Nov 18, 2012 8:21 am
Johno
If you can find the part number for the bit you need I will check which other models and years used it. You may find it easier to get a complete carb from a less popular model that uses the same lifter.
Pretty complete 650 carbs also come up on eBay from time to time if you keep your eye on that.
Try a pm to Crofty or Guyzed on here? they have 650 some bits.
From Mark
GUYZED
#5 PostAuthor: GUYZED » Sun Nov 18, 2012 4:43 pm
Do you mean the starter plunger/lever x4 of them John...part number 16068-014?
#449
Z1000A2 Z650B1
johno
#6 PostAuthor: johno » Sun Nov 18, 2012 5:05 pm
yes that sounds like them lifts the choke last one on carb 4 right hand side when your sat on the bike, been a job to start from cold guess only 3 carbs chokeing wont helping do you have any bit for sale?.
cheers john.
pertonpc
#7 PostAuthor: pertonpc » Sun Nov 18, 2012 5:57 pm
Hi Guyz,
Can't find the number Guy mentioned on my list.
If what you want is no. 47 on this diagram -
http://www.cmsnl.com/kawasaki-1978-kz65 ... ml#results
then it is part ref 13168-1026 called a lever, starter plunger
which came fitted to these bikes -
Model (25):
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B1 (KZ1000 LTD) (1977)
KZ1000-B2 (KZ1000 LTD) (1978)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C1 (Police 1000) (1978)
KZ1000-C1A (Police 1000) (1978)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D1 (Z1R) (1978)
KZ1000-D3 (Z1R) (1980)
KZ1000-E1 (Shaft) (1979)
KZ1000-E2 (Shaft) (1980)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ650-H1 (CSR) (1981)
KZ900-A4 (1976)
KZ900-A5 (1977)
KZ900-B1 (LTD) (1976)
johno
#8 PostAuthor: johno » Sun Nov 18, 2012 6:11 pm
yeah thats great my bike is a 77 b1 but 47 looks right now all i have to do is find one!!, thanks for you help its much appreciated, i have to sell my z1 and my h2 gutted so i need to sort the b1 its a nice bike.
cheers john.
GUYZED
#9 PostAuthor: GUYZED » Mon Nov 19, 2012 1:46 pm
John...if the part your after is number 47, i have some on a old set of Z650 carbs...P.M. me your address and i'll send them to you.
Is it just the one you want or a full set of four :?:
#449
Z1000A2 Z650B1
johno
carb arm
#10 PostAuthor: johno » Mon Nov 19, 2012 2:17 pm
just want to say a big thanks to guyzed and you others for your help its been much appreciated should make the old b1 a bit happier on a cold morning!!!
cheers john
johno
#11 PostAuthor: johno » Mon Nov 19, 2012 2:59 pm
guy are there any meets or shows coming up?
cheers john
#12 PostAuthor: Ginger Bear » Mon Nov 19, 2012 6:57 pm
johno wrote:guy are there any meets or shows coming up?
cheers john
John, Looks like a few of the 'usual suspects' might be here;
http://www.z1ownersclub.co.uk/forum/vie ... hp?t=22711
# 104
johno
curry
#13 PostAuthor: johno » Mon Nov 19, 2012 7:02 pm
sounds good to me!!![/quote]
GUYZED
#14 PostAuthor: GUYZED » Mon Nov 19, 2012 7:37 pm
John...the carb arm was posted this afternoon...you should get in the next day or so :D
#449
Z1000A2 Z650B1
johno
carb arm
#15 PostAuthor: johno » Mon Nov 19, 2012 7:43 pm
thank again guy have sent you a pm
best john :D
