Lockup Clutch set up
#1 PostAuthor: Pigford » Fri Aug 03, 2007 12:54 pm
Just got hold of an MRE lock up clutch kit from USA (eBay) :wink:
Anyone got any tips about fitment :?:
Seems quite straight forward, already got proper casing cover so won't foul :roll:
Any advice welcome before i try and start to set it up :P
Jeff Saunders
#2 PostAuthor: Jeff Saunders » Fri Aug 03, 2007 10:45 pm
When you install it you'll see the levers put pressure on the pressure plate - the issue is you need to modify the pressure plate - drill and install little teflon buttons to stop the levers from eventually cracking the pressure plate.
#3 PostAuthor: Pigford » Sat Aug 04, 2007 10:21 am
Thanks for that tip Jeff, sounds like good advice.
I'm gonna get a needle bearing, mushroom lifter from Steve (Debben) and would be happy for any DETAILED information/advice on Jeffs comments above for strengthening the end pressure plate. :|
Where can i get hold of teflon buttons or similar (nylon maybe) :?:
uk kev
#4 PostAuthor: uk kev » Sat Aug 04, 2007 10:32 am
do you need to split the cases to do the work you are doing? as I fancy one of the clutch lifters as well, I was going to call in Debbens next week to buy one. ask Jeff for a price for the buttons.
And take lots of pictures of the work so we can all learn from the Pigford master class :wink:
Padders
#5 PostAuthor: Padders » Sat Aug 04, 2007 10:43 am
These guys will sell you a modified pressure plate and are happy to give out any advise. I nearly bought a complete kit from them for the Harris.
E bay ref 4625845716
padders
#6 PostAuthor: Rich » Sat Aug 04, 2007 11:03 am
Kev - no just remove the clutch casing and pressure plate.
Pigford - some fit steel buttons to spread the load.
#7 PostAuthor: Pigford » Sat Aug 04, 2007 1:16 pm
Cheers guys!
Rich, can I locate some 'ready-to-fit' steel buttons, or do i just get some rod cut :?:
Any idea on size (diameter rod & length of cut buttons) :?
