And I mean an easy-fit - not after the application of a gas-axe
Z900 bodywork on a Z1000H ????
Does the older Z900/1000 round bodywork fit on a Z1000H frame
dixiethedog
Im not sure on the answer to your question,but I know the rear frame (spine)tubes hit the bottom of a tank if you try to fit z9 tanks on a z1000j. I know mk2 style tanks and panels can be made to fit z750 frames. I also know z1000j panels will fit Gpz750 uni tracs. I think the earlier of the zed frames should be ok,but the later J's and defo Gpz11 uni tracs need the frames modded.
Im planning on the possibility of mk2 panels onto my gpz7650 uni trac.
Have a look over in the project section on OSP,as Im sure a german chap was fitting older panels to his Gpz?
LOL,probably not a lot of use.
Every silver lining has a cloud...
Re: Z900 bodywork on a Z1000H ????
Pigford wrote:Does the older Z900/1000 round bodywork fit on a Z1000H frame![]()
Step away from the cooking sherry and put the silly ideas down
"Set the GRINDER on it"
dixiethedog
Z1000j frame with badly fitting z1 tank,which wouldnt fit over rear frame rails.
[img][img]http://i596.photobucket.com/albums/tt50/lindarobjones/robbies%20bike%20plus%20lindas%20old%20photos/102_0365.jpg[/img]
Gpz750 uni trac,from years ago with mock up of z650 panels.
[/img]
mk2 on z750 frame (i think?).
[img][img]http://i596.photobucket.com/albums/tt50/lindarobjones/project%20stuff/Picture141.jpg[/img]
[/img]
[img][img]http://i596.photobucket.com/albums/tt50/lindarobjones/project%20stuff/Picture148.jpg[/img]
Id be tempted to say anything will fit anything,with a big enough stick. lol.[/img]
[/img]
[/img]
Users browsing this forum: No registered users and 100 guests
