coldsummer wrote:Good to see you back Viktor and glad you weren't injured more badly. Looking forward to seeing the project restarted.
Seconded
zorded wrote:Paul will make up any sprocket you like and will also supply the bushes for the cush drive if that is what you have got.
I think the sprocket and bushes together was around the £100 mark, delivered.
Which type of rear hub is it?
zorded wrote:That looks identical to mine including the outer retaining disk. Might be as well to supply the PCD measurements as although it looks the same it also looks smaller somehow.
I have a sprocket here (secondhand) with old bushes in. How many teeth and what pitch are you aiming for?
The bushes are yellow when new by the way![]()
They also have shoulders on them that wrap around the holes in the sprocket.
