new member with Z900 project
Viktor Larsson
#136 PostAuthor: Viktor Larsson » Tue Jan 01, 2013 4:48 pm
Paint looks amazing with all the black. Can't wait to see it coming together more! :D
There's no replacement for displacement.
#137 PostAuthor: Rich » Tue Jan 01, 2013 7:28 pm
LondonZ1 wrote:Rich
That sounds like an excellent idea. Would copper high temp silicone gasket do the trick? I've already got some of that and I could still use the current studs. I plan to use aerotight nuts and there's just not quite enough thread for the locking ring to bite properly.
I doubt that will take the heat, this is what I meant:
http://www.ebay.co.uk/itm/Hylomar-Hylom ... 4abcfb32d5
LondonZ1
#138 PostAuthor: LondonZ1 » Wed Jan 02, 2013 5:48 pm
Rich, thanks for your help. I fitted 40mm allen bolts in the end. They shouldn't need to come out (as you say) and it makes it easier to judge how far the copper gaskets have compressed. Have now fitted the exhaust, which clears the wider swingarm easily. Just that stripped cam cap thread to sort out now before I try and start it up.
LondonZ1
#139 PostAuthor: LondonZ1 » Sun Jan 13, 2013 12:59 pm
The engine is still causing problems. I drilled out the damaged cam cap thread, inserted a thread repair coil (which is by far the most nerve-wracking part of the project to date) and thought I was done. Then I discovered that my black billet camshaft plugs don't sit flush with the top of the cylinder head casting. Looks like it's going to be plain rubber ones instead.
Still, I have got the exhaust fitted, and also the hydraulic clutch assembly, the rotor/stator and the seat. Best of all, I have stuck on the sculpture logos on the sides of the swingarm. I got various bits back from powder coating by Triple S and now have a smart oil filler cap, oil gallery plug and front brake splitter. To make up for the frustration with the engine, I decided to fit the tank, seat and tail piece for the first time and wheel it out for a few pics. This afternoon I plan to soak the clutch plates (new EBC ones) in oil and then finish off the clutch. The handlebars are Renthal streetfighter and I haven't decided whether they are quite right or not.
The exhaust is a PMC Monaka in stainless steel. The centre of the exhaust mounts to one of the centre stand brackets and the silencer clears the swingarm perfectly. This part of the project was causing me major problems and luckily it all seems to have worked out OK.
Steve Cooke
#140 PostAuthor: Steve Cooke » Sun Jan 13, 2013 1:34 pm
The cam end plugs often need a bit of tweaking just flat them down until they fit, mine fitted perfect one side but where well proud the other side due to the line bore on the head. Bike looks great so far.
#141 PostAuthor: Pigford » Sun Jan 13, 2013 1:51 pm
+ 1 with the APE cam caps - usually need a bit of a file :wink:
That looks FOOKIN' AWESOME :twisted:
mutz-nutz
#142 PostAuthor: mutz-nutz » Sun Jan 13, 2013 3:12 pm
:D on the last leg of your journey now m8 and its looking real fine a credit to all time and effort spent well done m8 :D
turn full circle and bite ya own arse !!
sanderz
#143 PostAuthor: sanderz » Sun Jan 13, 2013 3:38 pm
LondonZ1 wrote:
Stunning!! :drool
Wots up DOHC
morten
#144 PostAuthor: morten » Sun Jan 13, 2013 9:21 pm
Hi london Z1
Your Z1 is just going to be outstanding very very well done !!!!!!
It is so very correct buildt and with the very best of custom parts there is
and the colour cheme is butiful !!!
With all respect, and maybe you allready have thought about it but have you considered a other saddle? I like the one below or the one I have on my bike
to go with the Japanese custom style bikes.
But hey !! thats only my opinion anyway !! will work fine with the original also
This is the new seat from Bulldock racing the best!!
Image :twisted:
The one I have is from K-factory and is almost equal to the PMC one
LondonZ1
#145 PostAuthor: LondonZ1 » Sun Jan 13, 2013 10:17 pm
Thanks for the comments Morten. The two things I am still unsure about are the seat and the bars. I agree the seat doesn't look quite right and I have been thinking that black bars would look better. Luckily these are quite easy to change and I think I'll finish the rest of the bike before deciding. Despite appearances, there's still lots to do before it's ready for an MOT.
wierac21
#146 PostAuthor: wierac21 » Mon Jan 14, 2013 1:09 am
Absolutely love that front end setup LondonZ1! Especially the forks :drool
Tonto
#147 PostAuthor: Tonto » Mon Jan 14, 2013 10:09 am
Beautiful !!!!!!!!!!!!!
LondonZ1, that is one stunning looking bike you have built - love it !!
coldsummer
#148 PostAuthor: coldsummer » Mon Jan 14, 2013 10:36 am
It looks stunning, although I agree it would look even nicer with a custom seat and different bars.
Viktor Larsson
#149 PostAuthor: Viktor Larsson » Mon Jan 14, 2013 1:04 pm
Exhaust looks spot on! I agree with Morten regarding the seat, the Bulldock seat looks amazing!
LondonZ1
#150 PostAuthor: LondonZ1 » Mon Jan 14, 2013 1:24 pm
....as does the price!
The Bulldock seat is about £500.
