Z1000 A1 Fuel Tap Assembly
Paul Whitehouse
#1 PostAuthor: Paul Whitehouse » Thu Jan 31, 2013 9:02 am
Hi, I'm after a Z1000 A1 Fuel Tap Assembly....failing that, if somebody has the Fuel Tap Body with the filter intact that would be great. Cheers.
If it's too loud....too bad.
z1000puddin
#2 PostAuthor: z1000puddin » Thu Jan 31, 2013 12:50 pm
Paul,
I am sure I have one in my garage.
Let me check it out & get back to you.
stu
Zed til Dead
#3 PostAuthor: Pigford » Thu Jan 31, 2013 3:16 pm
I got one paul........ its dirty & works.... but the outlet has been "repaired" :??
z1000puddin
#4 PostAuthor: z1000puddin » Thu Jan 31, 2013 7:54 pm
Paul,
I have 2 in my stash,
One of them has a duel outlet at the back
The other has a duel outlet, but at different orientation.
Check out the picts. Both seem to work fine & I opened up one base & the seal still looks good.
Stu
Zed til Dead
Paul Whitehouse
#5 PostAuthor: Paul Whitehouse » Fri Feb 01, 2013 8:59 am
Cheers Stu and Mark.
Stu...I think it is the one on the left, in your photo, that I need....with the two outlets parallel. I have the old one off the bike that is in a bit of a sorry state...when I get home from work this evening I'll have a look to check the orientation of the outlets to make sure they are the same. I'll PM you later mate.
Thanks again guys, Paul
#6 PostAuthor: chrisu » Fri Feb 01, 2013 9:23 am
the one on the right is an A4 one I believe
