exhaust fumes
exhaust fumes
is there anything you can buy to put around the joint of an exhaust to prevent the fumes from escaping the collar is as tight as it can go but still some smoke gets out around the joint where it the centre part fits into the tail pipe. (not on a zed)
you need a silicone based sealant as some paste's go hard + then crack due to vibration
http://www.ebay.co.uk/itm/Kart-Wurth-Si ... 51a3ba737f
