z1000puddin wrote:Thanks guys,
I got some Vavoline 10w 40 today.So I will need to change this out for the semi synthetic, to see if this makes any difference to the clutch slip
But the bugger is, I have to remove my exhaust to change the bloody oil-
I Didn't really think of that one during the build did I![]()
zed1015 wrote:The needle clutch pusher is thicker than the std one.
Sounds like the push rod needed shortening to compensate.
The slave cylinders piston probably bottomed out in its bore when bolted up and permanently released the pressure plate.
Swapping the mushroom did the trick.
