Is it safe to drill Renthal bars?
LondonZ1
#1 PostAuthor: LondonZ1 » Sun Feb 17, 2013 7:36 pm
My bike has Renthal bars and H***a switchgear. The switches have a small protruding plastic pin on the inner surface that is designed to locate into a hole in the bars. If you grind off the locating pin, then the switchgear won't clamp the bars properly and it rotates round when pushed (don't ask how I discovered this...).
The Renthal instructions carry a big warning about not drilling the bars but I would have thought that a small (~3mm) hole towards the end of the bar would OK.
Any member got any experience/ thoughts on this? Thanks!
#2 PostAuthor: Pigford » Sun Feb 17, 2013 7:40 pm
Done loads of them with no hassle - just common sense and don't use any larger than a 1/2" bit :lol:
Mark Tiller
#3 PostAuthor: Mark Tiller » Sun Feb 17, 2013 8:30 pm
drill part way thru, enough to hold the pip
07962421462
jphaynes669
#4 PostAuthor: jphaynes669 » Sun Feb 17, 2013 9:09 pm
As mark said, only drill partway. I used renthals for over 20 season on the dirt and they
took a lot of stick aswell as being re used after straightening.
You wont hurt them . :wink:
Jeff.H
LondonZ1
#5 PostAuthor: LondonZ1 » Sun Feb 17, 2013 9:40 pm
Thanks guys, very helpful. I'll measure very carefully and then get the drill out. I've got a couple of spare handlebar clamps. I can drill a hole in one of them first and then clamp them around the bars and use them as a jig.
KWACKERZ1
#6 PostAuthor: KWACKERZ1 » Mon Feb 18, 2013 9:11 am
Just clamp them up with the pip in place and it will mark the bars where they need the hole. Saves drilling spare clamps.
