dust cover
wayno
dust cover
#1 PostAuthor: wayno » Sat Feb 16, 2013 6:53 pm
is the right hand side dust cover on a twin disc set up the same as a single disc only without the four bolt holes?
zmaxmotorsports
#2 PostAuthor: zmaxmotorsports » Sat Feb 16, 2013 7:06 pm
What kind of bike are you working on?
Im drawing a blank here :wink:
10-72 (build date)z1/2-74 z1s/2-75 z1s/77 1428 turbo/77 1170/78 1170/74 z1 1385 turbo nitrous project/80 1000ltd 1327 z1 clone.........
That ol kaw was fast on the draw
Outgunned suzukis and outrunned the law
wayno
#3 PostAuthor: wayno » Sat Feb 16, 2013 7:12 pm
sorry, its a z900 a4
#4 PostAuthor: z1bman » Sat Feb 16, 2013 8:14 pm
wayno
#5 PostAuthor: wayno » Sat Feb 16, 2013 8:29 pm
similar but to fit a single disc set up, cmsnl and kawasaki only list the part no 41042016 which has 2 screw holes not 4 bolt holes
#6 PostAuthor: z1bman » Sat Feb 16, 2013 8:49 pm
the two hole type that you have supplied the part no for will only fit the right side the speedo side looks like this
http://www.ebay.co.uk/itm/78-Kawasaki-K ... 337bdda750
zmaxmotorsports
#7 PostAuthor: zmaxmotorsports » Sun Feb 17, 2013 12:21 am
That's what was throwing me was the 4 holes! :lol:
wayno
#8 PostAuthor: wayno » Sun Feb 17, 2013 9:02 am
i have seen the two hole covers on ebay ocasionally but not the 4 hole. i will get one and drill the disc bolt holes
000zeds
#9 PostAuthor: 000zeds » Sun Feb 17, 2013 10:45 am
Which 4 bolt cover do you require ? Left side with speedo drive or right side as I have both !
Zeds-R-Us
#10 PostAuthor: z1bman » Sun Feb 17, 2013 1:28 pm
this is the dust cover for the speedo drive
wayno
#11 PostAuthor: wayno » Sun Feb 17, 2013 4:55 pm
this is getting confusing so full story, i am in the slow process of restoring a uk z900 a4 twin disc, few months ago i sent some bits to mikey for plating/chroming, the left side-speedo went to him but the right side got left behind. so as there seems to be right side dust covers on ebay quite regular i thought maybe i could get one and drill the 4 holes to make one if they are the same apart from the holes. hope it makes more sense.
wayno
#12 PostAuthor: wayno » Sun Feb 17, 2013 4:57 pm
twozeds wrote:Which 4 bolt cover do you require ? Left side with speedo drive or right side as I have both !
cheers two zeds, i have both just one got left behind when sent for chroming.
#13 PostAuthor: z1bman » Sun Feb 17, 2013 6:10 pm
wayno
#14 PostAuthor: wayno » Sun Feb 17, 2013 7:30 pm
z1bman wrote:this is the one i think ?
http://www.ebay.co.uk/itm/Kawasaki-KZ65 ... 0987646818
thats the one, expensive tho at about £45, bound to be a cheaper one along.
#15 PostAuthor: z1bman » Sun Feb 17, 2013 9:17 pm
