As per title, does anyone know if the GPZ750 R1 (earliest one) fit into a Z650 frame?
If the answer is yes, would the std 650 carbs be compatible dimension wise?
Cheers for any answers.
Will a GPZ750 motor fit into a z650 frame?
- coldsummer
I have seen GPZ1100 engines in Z650 frames. The way to go . .. .. .. .. ..
- coldsummer
- irhobotolo
irhobotolo wrote:ADRIAN H wrote:I have seen GPZ1100 engines in Z650 frames. The way to go . .. .. .. .. ..
but only in a straight line ....
think this will go around corners.
http://www.z1ownersclub.co.uk/forum/vie ... sc&start=0
