kiwi kdx wrote:haha i thought so......
im running a stock CRB1000 RR undertail in my GPZeleven, but im thinking the opposite ill need to open it up.
Kiwi - That will waken the neighbours
vduk wrote:If it's M6 you'd do better open the whole lot ip to M8 as they did on the later Zeds. I have a vague memory of replacing all my studs with the engine in the frame.
Pigford wrote:vduk wrote:If it's M6 you'd do better open the whole lot ip to M8 as they did on the later Zeds. I have a vague memory of replacing all my studs with the engine in the frame.
Stu is talking about the STUD thread Ralphy![]()
Stu - you're right about the risk involved in removing the studI don't see any reason you can't use a die to end up with an M5 - apart from ORIGINALITY
vduk wrote:Even if it's a pig to get out, it can still be done in situ. I have drilled studs out on Zeds in the frame. Snot easy, but it can be done. Best get one of those stud extractors with the caged rollers. I've found them great. If the fecker does shear off, just get some one to sight you in when you drill it out. Before getting started with the stud extractor, warm the engine up so that the aluminium head with expand more then the ms stud so make it keener to come out.
