Guyzz
As title says i am after the plastic part of the clutch mechanism that bolts inside the clutch housing and has the threaded adjuster screwed into it .
Hope you know what i mean
phil
Clutch inner plastic part
International Rep
International Rep
clutch worm gear
If you get stuck ive got one
Andy
Andy
http://www.cmsnl.com/kawasaki-1978-kz10 ... ml#results
Item no. 19
I hope i've identified the right bit Phil ?
Item no. 19
0172 . Geoff Parr
