Short throttle and clutch cables & longer rear brake hose.
Paul Whitehouse
#1 PostAuthor: Paul Whitehouse » Tue Mar 05, 2013 2:14 pm
Anybody know of a company where I can purchase some `short length` throttle and clutch cables for a Z1000 A1?....I'm running drag bars so need shorter than standard.
Also, due to the fact that my drag style `club foot` swing arm is way longer than standard but I am running a standard Z1000 rear brake cylinder assembly and calliper setup does anyone know of somewhere that would make, or I can buy, a longer length of brake hose to suit?
Cheers, Paul
If it's too loud....too bad.
Crofty
#2 PostAuthor: Crofty » Tue Mar 05, 2013 2:21 pm
Try Venhill, did me a one off rear brake hose for my special, will be using them for my fronts soon. They do throttle and clutch cables too. Crofty
scott
Junior Section leader
#3 PostAuthor: scott » Tue Mar 05, 2013 2:35 pm
I'm using drag straight bars on my z1000a2 and found z650 throttle and clutch cables were perfect.
Paul Whitehouse
#4 PostAuthor: Paul Whitehouse » Tue Mar 05, 2013 3:46 pm
Crofty and Scott...thanks for the info. chaps.
sanderz
#5 PostAuthor: sanderz » Tue Mar 05, 2013 6:18 pm
Demon Tweeks have a 'build a line' service although im sure they buy direct off Goodridge.
Hose available in clear, carboline and black colour coating.
Fittings - Stainless or Black Stainless.
Hose length in clear (ie 425mm long) listed as SB0425CL available in 25mm increments. You'd also require the Banjo Adapters either end
Straight - SBK592-03C
20* -SBK593-03C
45* - SBK594-03C
20* side banjo adapter - SBK597-03C
+ Banjos and copper washers
Direct order tel - 01978 664474
Taken from one of there catalogues (no prices tho')
Hope this helps :wink:
Wots up DOHC
Paul Whitehouse
#6 PostAuthor: Paul Whitehouse » Wed Mar 06, 2013 1:49 pm
Brilliant Sanderz...many thanks.
FOZ1A
z1000
#7 PostAuthor: FOZ1A » Wed Mar 06, 2013 2:03 pm
Paul, get your arse and the bike down to Venhill and they will make cables and lines to suit, that way there is no guess work involved!
foz
Steve S
#8 PostAuthor: Steve S » Wed Mar 06, 2013 4:54 pm
Agree with Foz on this one (how are you long lost buddy?) Venhill and they are fairly local to us :wink:............Long way to push the bike though Paul :lol:
Steve S
#9 PostAuthor: Steve S » Wed Mar 06, 2013 4:55 pm
Paul Whitehouse
#10 PostAuthor: Paul Whitehouse » Thu Mar 07, 2013 2:46 pm
What long lost buddy are you refering to?....you won't get hold of Foz...he's always on the golf course !!!! You'll have to give me a tow to Venhills using your KH250 !!!
sanderz
#11 PostAuthor: sanderz » Thu Mar 07, 2013 7:03 pm
This of any use to you, taken from Venhills site -
http://www.venhill.co.uk/Hoses_-_Compon ... RHOSE_PLUS
Wots up DOHC
