re inserted the liners with a weight on top and left to cool,job done
weaver wrote:popped the spare set in the oven today whilst the mrs was out...took them up slowly to 200 and "clunk" the barrels did indeed slide offremoved the liners and then the barrels,set the the block on some wood and then
zed1015 wrote:weaver wrote:popped the spare set in the oven today whilst the mrs was out...took them up slowly to 200 and "clunk" the barrels did indeed slide offremoved the liners and then the barrels,set the the block on some wood and then
Told you it was easy didn't i![]()
Did mention earlier that you might have to skim the liner tops flush with the barrel face though.
