How many milesfrom a chain
Hi Guy's
How many miles would you expect to get from a drive chain?
And what is the best drive chain lubricant?
Reason for asking. This is to help my wife understand why I keep needing to change the chain and sprokets.
It took her years to under stand that tyres wear out and need replacing.
I have not tried to explain about oil and filters yet.
Right hand
Zeith,
I can tell her, its because I am quick with my right hand, she might get the wrong idea. Any way, these days it is only good for peeing.
The chain and sproket I am changing has done 1661 miles.
Re: Right hand
Re: Right hand
Yike! !!..............
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- chrispyduck
Wurth Dry Lube........the best innovation for motorcycles
Used it for years.
Thrashed through Europe in torrential rain many times, a few British winters, ridden the Nurburgring, a few 180 blasts down the autobahn and still on the original chain and sprockets at 25000 miles.........on a ZX 12
Tyre life is shit tho
Used it for years.
Fat girls are like M****s, they are fun to ride, you just don`t want your mates to see you.
Don't know about that, but there are always 80 chains in a mile
http://en.wikipedia.org/wiki/Chain_(unit)
- irhobotolo
Re: Right hand
StephenW wrote:The chain and sproket I am changing has done 1661 miles.
Have you done 600 of those miles at Santa Pod
As long as you fit new sprockets at the same time, all DID sealed ring chains are warranted for either 15000 or 25000 miles depending on the grade of chain you fit. That is clearly the one to be aiming for.
Most road bikes should only ever need one chain and sprocket replacement in their lifetime.
I get more than 1600 miles between adjustments !! You are doing something very wrong there mate.
Any decent spray chain lube is good enough to lube a sealed ring chain. It's only the outside that needs protecting from the weather.
Personally I either use Motorex clear lube, or Wurth dry lube - I do not like the waxy stuff. It can cause grit to stick to it and then you have a very effective grinding paste. ;)
Users browsing this forum: celger7 and 22 guests
