can't stop carb overflow
bunnysZ
Granny Magnet
#1 PostAuthor: bunnysZ » Sat Mar 09, 2013 1:13 pm
not a zed but a KLR
carb keeps overflowing through overflow pipe underneath,
butterfly has been adjusted and adjusted jet cleaned carb cleaned , no splits in drain pipe inside float bowl , when tested on a bench with a petrol tank it does not leak, but as soon as i put it on the bike and fit the tank , turn on the petrol it overflows again..?
any ideas.
#2 PostAuthor: z1bman » Sat Mar 09, 2013 1:21 pm
have you thoroughly cleaned out the tank + fuel tap
bunnysZ
Granny Magnet
#3 PostAuthor: bunnysZ » Sat Mar 09, 2013 3:17 pm
no would that make the carb leak , as it did have a fuel filter on it before which i threw away.
#4 PostAuthor: PAULJAC47 » Sat Mar 09, 2013 3:29 pm
Hi Bunny,when you test on the bench with a tank is it the same height above the carbs as when on the bike? just a thought it may be the head heigh.t if it more when on the bike may be just enough to overcome the float valve.make a manometer and strap it alongside the carb body,this will show you the fuel height,have you tested the float for leaks? Good luck Paul J
#5 PostAuthor: z1bman » Sat Mar 09, 2013 8:49 pm
even though you have a fuel filter minute particles will still get through + cause the fuel valve to not seat correctly . remove the fuel tap + empty the fuel into a clean container to see if there is any rust particles
#6 PostAuthor: Pigford » Sun Mar 10, 2013 8:26 am
Have you checked the BRASS TUBE in the float bowl - they can split :?:
zmaxmotorsports
#7 PostAuthor: zmaxmotorsports » Sun Mar 10, 2013 8:28 am
Does it do it all the time,is it a mechanical or vacuam petcock? :wink:
10-72 (build date)z1/2-74 z1s/2-75 z1s/77 1428 turbo/77 1170/78 1170/74 z1 1385 turbo nitrous project/80 1000ltd 1327 z1 clone.........
That ol kaw was fast on the draw
Outgunned suzukis and outrunned the law
bunnysZ
Granny Magnet
#8 PostAuthor: bunnysZ » Sun Mar 10, 2013 8:39 am
brass tube inside is ok and its a mechanical type
gray
#9 PostAuthor: gray » Tue Mar 12, 2013 7:44 pm
I had a problem on my GPZ9 last year , checked all the usual things , zilch.
then I had a good close look and saw it was leaking from one of the T pieces that accepts fuel from the hose and feeds it to 2 adjacent carbs. There's O rings in there that can perish , and leak if there's enough head of pressure and it looks like it's coming from the carbs but they'e fine when you drop the float bowls and check everything inside.
Trouble is you have to split the carbs to get at them , and the things are relatively dear , and you might as well do both T pieces since you've stripped it that far so that's 8 you need on a GPZ. They look Ok at first , then you roll them between your fingers and you see all the little cracks round the periphery.
gray
Users browsing this forum: celger7 and 42 guests
