Modified Front Brake Set up
#16 PostAuthor: Pigford » Thu Aug 23, 2007 7:41 pm
:oops: :oops: :oops: :oops:
RICH, A GOOD WAY TO IMPROVE YOUR BIKES PERFORMANCE, IS TO REMOVE THE DEAD-WEIGHT ATTACHED TO THE HANDLE BAR GRIPS & FOOT RESTS :wink:
Davy Doherty
#17 PostAuthor: Davy Doherty » Thu Aug 23, 2007 9:16 pm
The feckers arnt gonna let it go Pigford are they!!!
#18 PostAuthor: paul doran » Thu Aug 23, 2007 9:50 pm
too right we ain't especially since he won a set of spanner's for being a big spanner himself
Dodgy Z1B
#19 PostAuthor: Dodgy Z1B » Thu Aug 23, 2007 11:25 pm
go with the clear plastic tube on the bleed nipple and suck it through, it works for me every time, of course you need to open the nipple and i find it works better if you hold the brake lever in. I have a piece of tube about 3 feet long so i just suck it with me mouth, not the most sensible way i know but you get used to the taste after a while :). Mind it could just be that you have mixed some dot 4 with dot 3 or 5, as this would cause sponginess aledgedly.
