Engine paint
Rhencullen wrote:Big Fluff wrote:The Siminoz 'Tough Black' is even better that PJ1 I reckon.
Will have to give this Simoniz stuff a whirl guys, 'cos I'm sorely missing PJ1. Thanks for the heads up
Here ya go, bargain for 6 tins at just £28. http://www.ebay.co.uk/itm/370694765439? ... 1439.l2649
He sells gloss, satin, matt, 1 tin, 2 tin, 6 tin, 12 tin deals.... will even mix & match like he's done for me.
Regs, Will
- ZedHead
I'm about to spray my DR400 engine while it's in bits, is this Simoniz toough black good for air cooled cylinders? Couldn't see any info reg temperatures, not sure I'm looking at the right stuff ?
http://www.ebay.co.uk/itm/2-X-500-ML-SI ... 48414a24d4
hanskloss wrote:I'm about to spray my DR400 engine while it's in bits, is this Simoniz tough black good for air cooled cylinders? Couldn't see any info reg temperatures, not sure I'm looking at the right stuff ?
Yes! That's it and the Sperex tough black is the same stuff.
Treat it the same as PJ1.
See my cafe racer thread for the finish as i have done all the engine in it.
I have done small parts with the heat gun but i apply the heat opposite the painted side so that the heat radiates into the paint from the underside.
I also warm the part slightly to sweat out any moisture from the castings which give the paint a better key.
I have never just painted a cold complete engine for a cosmetic tart up so i don't know how long it will last in the long term.
The pj1 and simoniz etc is good stuff though so should stay looking good for quite a while if it's applied to a nice clean base.
mike_p wrote:anyone used the simoniz 'Tough Black' satin paint on an exhaust ? works a treat on the engine.....I'm just wondering how hot it would go
It peels off... I've been there.
I've used this for my bikes. Used on jet engines and can be sprayed from a HVLP gun. Satin black, cost about £45 for a litre. Done a few exhausts with it too.
http://www.indestructible.co.uk/IP9036R1/
Users browsing this forum: Robw and 98 guests
