Dyna S problem
Dyna S problem
Hi lads, need some help/advice. Got a Dyna S ignition and coils fitted. Fires ok on 1/4 but no spark on 2/3. New coils fitted and I have swapped the leads over and coils ok. According to Dyna its a module gone down, any suggestions and has anyone got a spare I could borrow/buy?
foz
foz
I would swapping the modules over to be 100% sure.
If you cant see a white substance under the module you can be sure its had it.
Ive got an dyna s with a one module working.i could sell you the hole unit.
keep thoses wheels turning
Im not sure how common this is.But i had a electrical short prob once.In the process of sorting it the dyna s blow.I notice there is now fuse to protect it.
SO IF YOU EVER HAVE A ELECTRICAL PROBLEM.DISCONNECT THE DYNA TILL SORTED
- big green bus
- steve bowdler
z2.john wrote:Have to say Dyna units are over rated.
My first one failed after about 18 months on 1/4. I put it down to bad luck since everyone seems to think they are the dogs, so I bought another and that too failed after about 9 months.
Be interested to know how many other failures are out there
My wife says "I'm a failure" !!!
Jimmock.
I hate people I don't like !
- big green bus
Have a Dyna S, on my zed 5+ years no problems. A lot better than buggering about with points.
Users browsing this forum: Bing [Bot] and 44 guests
