I know its not a Z1 but thought I would share my project if any one is interested.
What originally started off as a strip and tidy of my 750 has turned in to a major strip down as the frame is rusty and needs blasting and powder coating, the pictures just dont show how filthy, oily, rusty and neglected this bike is.
In transit.
Loads of rust where mud has collected.
When I took off the tank, something was rattling inside, I thought it would of been something broke off the fuel level float, instead it was a AEG Trovan 300 which after searching appears to be a transponder possibly off the data tag.
The swinging arm and underside of the frame andengine is covered in 17 years of mud and oil.
The calipers were seized solid with rust, I had to remove the calipers to push the bike.
Rocker cover gasket has definately been leaking.
