ZRX SPARK PLUGS
bunnysZ
Granny Magnet
ZRX SPARK PLUGS
#1 PostAuthor: bunnysZ » Thu Apr 25, 2013 2:36 pm
how do you get the 2 centre spark plugs out of a ZRX, the frame and wiring are in the way , and the plug cap is too long to remove, any tips before i remove the wiring.
Big Fluff
#2 PostAuthor: Big Fluff » Thu Apr 25, 2013 3:25 pm
I think you have to remove the coils... M6 nuts that's all, I think.
Has been a while since I changed mine but it ain't no big deal if I remember correctly. :roll:
#3 PostAuthor: paul doran » Thu Apr 25, 2013 4:10 pm
You can get them out Bunny if You can borrow a plug spanner with a knuckle joint
I have one and I can remove the plugs without having to remove any parts
sorry I am so far away or You could borrow mine
#4 PostAuthor: chrisu » Thu Apr 25, 2013 5:12 pm
paul,
do you have the plug spanner from the original toolkit
will -failing that can you post a picture of what you use and i'll see if i have something similar
i don't remember having a problem when i changed the plugs on mine but that was about 5 years ago.
#5 PostAuthor: z1bman » Thu Apr 25, 2013 5:46 pm
no 2+ 3 can be a little difficult to get out just spray some wd40 around the caps + they will come out easily. no need to remove the coils if you have a decent set of tools just a 3/8 long extension + knuckle joint make sure the caps are pushed right down when re assembling they have a tendency to collect water + the water boils like a kettle + blows the plug cap of the spark plug + you end up with a misfire or only running on three cylinders. look into the core of the cap to make sure it has no corrosion
Big John
#6 PostAuthor: Big John » Thu Apr 25, 2013 5:59 pm
I've found the spark plug socket in the original toolkit will get 2 & 3 out although a bit fiddly.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
bunnysZ
Granny Magnet
#7 PostAuthor: bunnysZ » Thu Apr 25, 2013 8:05 pm
yes i do have one of those knuckle jobs, thanks for the advice , it will help chrisu when he comes over sat ... :D
Users browsing this forum: No registered users and 172 guests
