I'm going to have a crack at a new loom as my build nears assembly. But work may keep me away from it in the coming weeks / months and I WILL have this bike on the road for Summer.
Anyone know or recommend a good bike electrician in the SW area or within 100miles of London?
I jave a full garage space available and you can park your car / van right inside next to the bike of you need to with power and lighting all there.
Also, the loom is super simple - no clocks or indicators, its basically a lights / electric supply / engine / starter - thats it! Will also be using a MotoGadget so no relays or fusebox its pretty plug and play - ann all componentry is brand new so no manky bits to deal with.
The 95% confirmed loom is as below.
One important note - I'll be fairly fussy about where the cabling runs - want it as hidden as possible and I'd like quality terminations / plugs. No crimps / block connector etc.
If anyone wants to quote or knows anyone - please let me know.
I can also drop the bike to you if you are not far.
