Could anyone tell me where i could download a manual for a gpz1100 ut 1983 ? I have tried a couple of times and ended up with a gpz750 instead !!
Cheers in advance Andy ........
GPZ1100 UT 1983
martinz1000r
Andy, Unitrak is a supplement to the main KZ1000 workshop manual. They come up on ebay regularly but it's useless on it's own as it constantly refers you to the base manual. Do you need a specific as can probably copy and email you. Cant lend out whole lot as going to need it near future to set up shims.
snotie1965
martinz1000r wrote:Andy, Unitrak is a supplement to the main KZ1000 workshop manual. They come up on ebay regularly but it's useless on it's own as it constantly refers you to the base manual. Do you need a specific as can probably copy and email you. Cant lend out whole lot as going to need it near future to set up shims.
Yes cheers martin for info ,it`s for different things on the bike ie: the oil hose junction has two larger o rings and one small o ring but when you look at the crank casing there is only 3 cut outs for the o rings ? it just seems strange that there is not a cut out, or o ring on the 4th oil return ? and it has no heli coils or other things different ?
And Gus is posting me a cd
cheers Andy ...........
Users browsing this forum: Bing [Bot] and 161 guests
