GPZ1100 UT 1983
snotie1965
GPZ1100 UT 1983
#1 PostAuthor: snotie1965 » Thu May 09, 2013 11:19 am
Could anyone tell me where i could download a manual for a gpz1100 ut 1983 ? I have tried a couple of times and ended up with a gpz750 instead !!
Cheers in advance Andy ........
martinz1000r
#2 PostAuthor: martinz1000r » Thu May 09, 2013 12:01 pm
Andy, Unitrak is a supplement to the main KZ1000 workshop manual. They come up on ebay regularly but it's useless on it's own as it constantly refers you to the base manual. Do you need a specific as can probably copy and email you. Cant lend out whole lot as going to need it near future to set up shims.
Gus
#3 PostAuthor: Gus » Thu May 09, 2013 1:07 pm
Andy.
Send me an email and I'll send you a pdf.
Gus
Ballderdash to that!! it's 48Mb
I'll burn you a copy and post it if you let me have your address
Gus
"Set the GRINDER on it"
snotie1965
#4 PostAuthor: snotie1965 » Thu May 09, 2013 4:49 pm
martinz1000r wrote:Andy, Unitrak is a supplement to the main KZ1000 workshop manual. They come up on ebay regularly but it's useless on it's own as it constantly refers you to the base manual. Do you need a specific as can probably copy and email you. Cant lend out whole lot as going to need it near future to set up shims.
Yes cheers martin for info ,it`s for different things on the bike ie: the oil hose junction has two larger o rings and one small o ring but when you look at the crank casing there is only 3 cut outs for the o rings ? it just seems strange that there is not a cut out, or o ring on the 4th oil return ? and it has no heli coils or other things different ?
And Gus is posting me a cd :) Well chuffed !!!!
cheers Andy ...........
