front brake master cylinder
bunnysZ
Granny Magnet
#1 PostAuthor: bunnysZ » Thu Aug 30, 2007 11:15 am
can anyone tell me if ebay item 300145462958. front brake master cylinder is for the twin disc or single disc.
also would a 2003 z1000 front brake master cylinder fit straight on without any modifications,
cheers
#2 PostAuthor: Pigford » Thu Aug 30, 2007 6:26 pm
BunnysZ, Any newer model master cylinder should work. I've used various modern brake bits, GSXR & Yamaha over the years, and as long as they're for a twin set up, should be fine :wink:
doebag
#3 PostAuthor: doebag » Sat Sep 01, 2007 7:53 am
Morning,
Hard to tell from the part number. The numbers can change for something simple like if it is black or silver finish.
You could try looking on www.buykawasaki.com and seeing if the part number matches your model or a similar model with twin discs.
The parts books for my Z1100A and GPz1100 show four different part numbers, for what is essentially the same brake set up. They are both twin disc but are not the number on the Ebay item. The books even show a different number for the same bike in a different sales country.
'Dying a'int much of a living, boy'
Outlaw Josey Wales
Member No. 555
bunnysZ
Granny Magnet
#4 PostAuthor: bunnysZ » Sat Sep 01, 2007 11:15 am
cheers doebag, and welcome to the site.
think i will go down the rd of the 2003 master cylinder, fed up with leaking old ones.
outlaw josey wales excellent film
